membersegments
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
collectioncentroid
The centroid of the collection of intersecting entities of the member section.
Type: triple double
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 – Skeleton
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
endmembersection
The ID of the member section at the end.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
parentmember
The ID of the parent member that owns this member segment.
parentsegment
The ID of the parent member segment.
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
segmentparamend
The parametric end value of the member segment with reference to the parent member.
Type: double
segmentparamstart
The parametric start value of the member segment with reference to the parent member.
Type: double
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
startmembersection
The ID of the member section at the start.
symmetryid
The ID of the symmetry plane.
Type: entity
Version History
2022
