comments
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
commentkeyword
Stores any LS-DYNA keywords prefixed with *COMMENT.
Type: string
commentlines
The comment text.
Type: string array
config
The configuration of the entity.
101 - *COMMENT
401 – PAM-CRASH CDATA
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
entityids
Entities that are referred in the comment.
Entity types that can be referred: Accelerometer, Alesmoothing, Alefsiprojection, Aletanktest, Alereferencesystemcurve, Alereferencesystemgroup, Alereferencesystemnode, Alereferencesystemswitch, Component, Constrainedextranodes ,Constrainedrigidbody, Controlcard, Group, Controlvolume, Crosssection, Curve, Damping, Element, Friction, Hourglass, Initialgeometries, Interfacelinking, Interfacecomponent, Load, Loadcol, Material, Node, Outputblock, Parameter, Position, Pretensioner, Property, Rigidwall, Sensor, Set, Retractor, Slipring, Solvermass, Systemcol, Termination, Transformation.
Type: entity array
entityidsmax
Count of entities referred to in the comment.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
numberoflines
The number of comment lines.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2020
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names entityids,entityidsmax, internalname, and solvername.
2022.1 - Added new config value 401.
