aletanktests
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- amgida
- The ALE multi-material group ID (AMMGID) of the air.
- amgidg
- The ALE multi-material group ID (AMMGID) of the gas.
- aorif
- The total inflator orifice area.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- machl
- The limiting MACH number for the gas at the throat.
- mdotlc
- LCID for mass flow rate as a function of time.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- numpnt
- The number of points.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- pamb
- The tank pressure before jetting.
- pfinal
- The final equilibriated tank pressure after the tank test.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- tankv
- The tank volume.
- velmax
- The maximum allowable gas velocity across the inflator orifice.
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
