dvprels
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - c0
 - The constant in the dvprel.
 - coeff
 - A pointer to the list of real coefficients.
 - config
 - The configuration of the entity.
 - configname
 - The solver name of the entity. Valid for hm_getvalue query only.
 - definedentity
 - True if the entity is defined, false otherwise.
 - desvarlist
 - A pointer to the list of designvars.
 - desvarlistmax
 - The number of designvars.
 - fieldname
 - The field name for the respective field position for the property. For PSHELL, for field position 4, the field name is "Thickness T".
 - fieldposition
 - For all properties except PBARL and PBEAML this is the field number on the corresponding property card.
 - functionid
 - The ID of the design equation (DEQATN) referenced by the dvprel. If zero, the entity is a DVPREL1. If > 0, the entity is a DVPREL2.
 - globalply
 - The global ply toggle for PCOMPG.
 - globalplyid
 - The global ply ID for PCOMPG.
 - globalplyfieldname
 - The global ply field name for PCOMPG. This value is "Thickness" or "Orientation". Valid for hm_getvalue query only.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - pmin
 - The minimum value allowed for the property.
 - pmax
 - The maximum value allowed for the property.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - property
 - The type of property referenced by the dvprel. Valid values are:
- 1 - PSHELL
 - 2 - PSOLID
 - 3 - PSHEAR
 - 4 - PCOMP
 - 5 - PBAR
 - 6 - PBEAM
 - 7 - PELAS
 - 8 - PROD
 - 9 - PBEND
 - 10 - PDAMP
 - 11 - PBUSH
 - 12 - PTUBE
 - 13 - PGAP
 - 14 - ELEM
 - 15 - MAT
 - 16 - SETS
 - 17 - PBARL
 - 18 - HM_ELAS
 - 19 - PBEAML
 - 20 - PWELD
 - 21 - PMASS
 - 22 - PCOMPG
 - 23 - PCOMPP
 - 24 - PVISC
 - 25 - PLYS
 - propertyid
 - The ID of the referenced property.
 - propertyname
 - The name of the property type referenced by the dvprel. Valid for hm_getvalue query only.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - tableentrylist
 - Pointer to the list of table IDs.
 - tableentrylistmax
 - The number of referenced DTABLE tables.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
