frictions
Unless otherwise specified, data names are accessible in level 3 only.
- alpha1
- The rotation angle between direction 1, 2 and direction 1’, 2’.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- c1
- The default c1 friction law coefficient.
- c1_2
- The c1_2 friction law coefficient.
- c1_part
- The c1 friction law coefficient for specific parts or groups of parts.
- c2
- The default c2 friction law coefficient.
- c2_2
- The c2_2 friction law coefficient.
- c2_part
- The c2 friction law coefficient for specific parts or groups of parts.
- c3
- The default c3 friction law coefficient.
- c3_2
- The c3_2 friction law coefficient.
- c3_part
- The c3 friction law coefficient for specific parts or groups of parts.
- c4
- The default c4 friction law coefficient.
- c4_2
- The c4_2 friction law coefficient.
- c4_part
- The c4 friction law coefficient for specific parts or groups of parts.
- c5
- The default c5 friction law coefficient.
- c5_2
- The c5_2 friction law coefficient.
- c5_part
- The c5 friction law coefficient for specific parts or groups of parts.
- c6
- The default c6 friction law coefficient.
- c6_2
- The c6_2 friction law coefficient.
- c6_part
- The c6 friction law coefficient for specific parts or groups of parts.
- cid
- The contact ID to optionally limit friction scaling to one contact interface.
- coeff1
- The value of coefficient 1.
- coeff1
- The value of coefficient 2.
- coeffmax
- The maximum friction cut-off value (coefficient 0).
- coeffmin
- The minimum friction (coefficient 0).
- config
- 401 – PAM-CRASH FRICT
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- dc_d
- The default value of the exponential decay coefficient.
- dc_ij
- The exponential decay coefficient between parts i and j.
- definedentity
- True if the entity is defined, false otherwise.
- e_coef
- The damping coefficient of the exponential function.
- elastic_slip
- The amount of allowable slip.
- fd_d
- The default value of the dynamic coefficient of friction.
- fd_ij
- The dynamic coefficient of friction between parts i and j.
- fric
- The Coulomb friction value.
- fric_2
- fric_part
- The Coulomb friction value for specific parts or groups of parts.
- frict
- The friction coefficient.
- frict1
- The friction coefficient in direction 1.
- frict2
- The friction coefficient in direction 2.
- friction
- The friction_type friction coefficient.
- friction_format
- Specifies how friction is defined:
- friction_style
- When friction_format is 1, specifies the reference variable:
- friction_table
- When friction_format is 1, specifies the ID of the table containing friction_style values versus friction_type friction.
- friction_type
- Specifies the type of friction:
- fs_d
- The default value of the static coefficient of friction.
- fs_ij
- The static coefficient of friction between parts i and j.
- grpart_ID1
- The first part set identifier.
- grpart_ID2
- The second part set identifier.
- Grpart_Part_Type
- The Grpart/Part type selector:
- icnep
- The flag to check for non-existing parts, or part sets:
- id
- The ID of the entity.
- i1f
- The index for the contact pressure axis in lookup table.
- i2f
- i3f
- icoufr
- The flag controlling the Coulomb friction type per part.
- Idir
- The flag for orthotropic friction:
- idlku
- The ID of the curve representing the lookup table.
- ifiltr
- The friction filtering flag:
- iform
- The friction penalty formulation type:
- ifric
- The friction formulation flag:
- ifropt
- The type of the friction model.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- iorth
- The orthotropic system formulation flags for reference vector:
- ipcur
- The ID of the curve defining the friction coefficient versus contact pressure.
- ivcur
- The ID of the curve defining the friction coefficient versus sliding velocity.
- lcid
- The ID of the load curve defining the coefficient of friction versus orientation angle.
- lcidp
- The ID of the load curve defining the coefficient of friction versus pressure.
- max_shear
- The maximum shear stress when maxshear_format is 0.
- maxshear_format
- Determines how the maximum shear stress is defined:
- maxshear_style
- When maxshear_format is 1, specifies the reference variable:
- maxshear_table
- When maxshear_format is 1, specifies the ID of the table containing maxshear_style values versus maximum shear stress.
- moduleid
- The module ID of the entity.
- N
- The number of friction values for specific parts or groups of parts.
- name
- The name of the entity.
- n_orient
- The number of friction orientations.
- numfrict
- The number of contact part pair definitions.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- part_ID1
- The first part identifier.
- part_ID2
- The second part identifier.
- pfrict
- The constant friction coefficient to be used between the two defined parts.
- phi
- The angle.
- pid
- The part ID to which directional and pressure-sensitive coefficient of friction is to be applied.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- psid
- The part set ID to optionally limit friction scaling to parts in the set.
- ptype_i
- The part i entity type:
- ptype_j
- The part j entity type:
- scalei
- The friction scale factor for the inner surface of the shell elements.
- scaleo
- The friction scale factor for the outer surface of the shell elements.
- skew_id
- The skew identifier for reference vector.
- slip_tolerance
- The allowable slip tolerance.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- v1
- The 1-component of the vector defining the 0-degree direction.
- v2
- The 2-component of the vector defining the 0-degree direction.
- v3
- The 3-component of the vector defining the 0-degree direction.
- val1
- The user-defined parameter 1.
- val2
- The user-defined parameter 2.
- val3
- The user-defined parameter 3.
- val4
- The user-defined parameter 4.
- val5
- The user-defined parameter 5.
- val6
- The user-defined parameter 6.
- val7
- The user-defined parameter 7.
- val8
- The user-defined parameter 8.
- val9
- The user-defined parameter 9.
- val10
- The user-defined parameter 10.
- val11
- The user-defined parameter 11.
- val12
- The user-defined parameter 12.
- val13
- The user-defined parameter 13.
- val14
- The user-defined parameter 14.
- val15
- The user-defined parameter 15.
- val16
- The user-defined parameter 16.
- vc_d
- The default value of the viscous friction coefficient.
- vc_ij
- The viscous friction coefficient between parts i and j.
- vis_f
- The default value of critical damping coefficient on interface friction.
- vis_f_2
- The critcal damping coefficient on interface friction.
- vis_f_part
- The default value of critical damping coefficient on interface friction for specific parts or groups of parts.
- vx
- The x component for reference vector.
- vy
- The y component for reference vector.
- vz
- The z component for reference vector.
- xfreq
- The filtering coefficient.
Version History
2020
2020.1 - Added new data names c1_2, c2_2, c3_2, c4_2, c5_2, c6_2, e_coef, elastic_slip, fric_2, friction, friction_format, friction_style, friction_table, friction_type, Grpart_Part_Type, Idor, iorthmax_shear, maxshear_format, maxshear_style, maxshear_table, n_orient, phi, slip_tolerance, skew_id, solverkeyword, vis_f_2, vx, vy and vz. Added new config value 601.
2021 - Added new data names cid, icnep, psid, scalei and scaleo.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022 - Added new config values 401, 402. Added new data names coeff1, coeff2, coeffmax, coeffmin, frict, frict1, frict2, i1f, i2f, i3f, icoufr, idlku, ifropt, ipcur, ivcur, numfrict, pfrict, val1, val2, val3, val4, val5, val6, val7, val8, val9, val10, val11, val12, val13, val14, val15, and val16.
