members
Unless otherwise specified, data names are accessible in level 3 only.
_baseFlags
The base flag of the entity.
Type: unsigned integer
_representations
The representations of the entity.
Type: entity array
_representations_functionalrepresentation
The functional representations of the entity.
Type: entity array
_representations_geometricrepresentation
The geometric representations of the entity.
Type: entity array
_representations_solverrepresentation
The solver representations of the entity.
Type: entity array
_subType
The sub type of the entity.
Type: string
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
1 - Skeleton
controllocations
A list of 3D co-ordinates that define the member. Each co-ordinate is a triple of type double.
Type: triple double array
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
endmemberjoint
The ID of the member joint at the end.
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
membersections
The list of member sections contained in the member.
Type: entity array
membersegments
The list of member segments contained in the member.
Type: entity array
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
numcontrollocs
The number of control locations of the member.
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
primaryrepresentation
The current representation of the panel.
Type: entity
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
startmemberjoint
The ID of the member joint at the start.
symmetryid
The ID of the symmetry plane.
Type: entity
symmetryparent
The ID of the parent member used for symmetry.
Version History
2022
