structuralproperties
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- length
- The length of the panel when config is 100, 400 or 401.
- material
- The material of the panel when config is 400 or 401.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- property
- The assigned property.
- radius
- The radius of the panel when config is 400 or 401.
- rivetdia
- The diameter of the rivet when config is 118.
- se_aimingtype
- The aiming method for the tangent to trajectory positioning method.
- se_armlength
- The arm length of the headform impactor.
- se_contactdist
- Shows the resulting contact distance between the contact point and design point location.
- se_contactpoint
- The location of the contact point of the impactor.
- se_hangle
- The horizontal angle used for positioning in degrees.
- se_headcenter
- The location of the center of the impactor headform.
- se_ip_activate
- True if the design point is active.
- se_ip_adult
- 1 if the design point is an adult type, 0 otherwise.
- se_ip_angle
- The angle of the impactor for child/adult or leg pedestrian impact points.
- se_ip_areacheck
- When se_ip_positiontype is 3 and this is set true, a check is made to see if the impactor’s COG is out of test area (w.r.t side reference lines). If so, automatically reposition the impactor using the 2D touch point.
- se_ip_cog
- The coordinates of the location of the COG of the design point.
- se_ip_comment
- The comments related to the parent design point.
- se_ip_energy
- The impactor energy of the design point.
- se_ip_gap
- The gap distance between impactor and vehicle outer used during positioning.
- se_ip_groundzcord
- The z-height of the ground plane used for marking.
- se_ip_horizontallyprojected
- True of the design point is horizontally projected.
- se_ip_mass
- The mass of the impactor used for the parent design point.
- se_ip_positiontype
- The method used for placing the impactor on the design point:
- se_ip_testtype
- The test used for the parent design point:
- se_ip_velocity
- The velocity of the impactor used to test impact points.
- se_ip_zheight
- The z-height to consider from ground for lower legform positioning.
- se_moveback
- The magnitude of the move back distance (in the normal to target or target angle method) or angle (in degrees) in the case of the tangent to trajectory or pivot angles method.
- se_normal
- The normal unit vector to be used in the normal to target method of positioning.
- se_pivotpoint
- The desired location of pivot point used in the pivot angle method of positioning. This field will store the final location of the pivot point also for the tangent to trajectory method of positioning.
- se_positioningtype
- The positioning method to be used in the Instrument Panel impact process.
- se_regulation
- The regulation method used in the Instrument Panel impact process.
- se_srp
- The location of the seat reference point of the vehicle.
- se_vangle
- The vertical angle used for positioning in degrees.
- se_zlevel
- The z level in the tangent to the trajectory positioning method. Z level is defined as the global z coordinate of the headform impactor after positioning.
- sebeamsect
- The beam section ID when config is 100.
- sematerial
- The material ID.
- se_tp_allowed_deviation_x_neg
- The allowed negative deviation for the abscissa of the measurement node. This value will be used for the color coding and the computation of num_failed_coords data name of the design point (with config 81), which references the current structural property. Allowable values are non-positive.
- se_tp_allowed_deviation_x_posi
- The allowed positive deviation for the abscissa of the measurement node. This value will be used for the color coding and the computation of num_failed_coords data name of the design point (with config 81), which references the current structural property. Allowable values are non-negative.
- se_tp_allowed_deviation_y_neg
- The allowed negative deviation for the ordinate of the measurement node. This value will be used for the color coding and the computation of num_failed_coords data name of the design point (with config 81), which references the current structural property. Allowable values are non-positive.
- se_tp_allowed_deviation_y_posi
- The allowed positive deviation for the ordinate of the measurement node. This value will be used for the color coding and the computation of num_failed_coords data name of the design point (with config 81), which references the current structural property. Allowable values are non-negative.
- se_tp_allowed_deviation_z_neg
- The allowed negative deviation for the applicate of the measurement node. This value will be used for the color coding and the computation of num_failed_coords data name of the design point (with config 81), which references the current structural property. Allowable values are non-positive.
- se_tp_allowed_deviation_z_posi
- The allowed positive deviation for the applicate of the measurement node. This value will be used for the color coding and the computation of num_failed_coords data name of the design point (with config 81), which references the current structural property. Allowable values are non-negative.
- se_tp_measurement_node
- The node located on the dummy.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- tableid
- The user data table ID.
- width
- The width of the panel when config is 400 or 401.
Version History
2019.1
2020 - Added new data names color_rgb, length, material, radius, se_ip_activate, se_ip_adult, se_ip_angle, se_ip_areacheck, se_ip_cog, se_ip_comment, se_ip_energy, se_ip_gap, se_ip_groundzcord, se_ip_horizontallyprojected, se_ip_mass, se_ip_positiontype, se_ip_testtype, se_ip_velocity, se_ip_zheight and width. Added new config values 80, 81, 82, 400 and 401.
2020 - Added new config values 100 and 500. Added new data names sebeamsect, sematerial and tableid. Added length support for config 100.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022 - Added new data names se_tp_allowed_deviation_x_neg, se_tp_allowed_deviation_x_posi, se_tp_allowed_deviation_y_neg, se_tp_allowed_deviation_y_posi, se_tp_allowed_deviation_z_neg, se_tp_allowed_deviation_z_posi, and se_tp_measurement_node. Added new config value 83.
2022.1 - Added new config value 84 and new data names se_aimingtype, se_armlength, se_contactdist, se_contactpoint, se_hangle, se_headcenter, se_moveback, se_normal, se_pivotpoint, se_positioningtype, se_regulation, se_srp, se_vangle, and se_zlevel.
