symmetries
Unless otherwise specified, data names are accessible in level 3 only.
- active
 - The symmetry active flag 0/1.
 - activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - enforce
 - The symmetry mirror image mode.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - morphvolumes
 - If true, symmetry is to be applied to handles on morph volumes and to map to geom operations. Valid for hm_getvalue query only.
 - multilat
 - The symmetry directionality mode.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - orient
 - The orientation axis for the symmetry system.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - sysptr
 - The ID of the associated local coordinate system.
 - type
 - The type of symmetry.
 - ucyc
 - The number of wedges for cyclical symmetry.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
