seamexcitations
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - APPLIEDLOAD_VARIABLE
 - The type of reverberant applied load.
 - attributesmax
 - The number of attributes owned by this entity.
 - BANDWIDTH_TYPE
 - The frequency bandwidth type of excitation load.
 - CASE_NO
 - The case type of solver entity written out in the .exc solver deck file.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - EXC_BANDWIDTH
 - The excitation bandwidth type of solver entity written out in the .exc solver deck file.
 - EXC_VALUE
 - The solver attribute for excitation value after generation of excitation list written in the .exc solver deck file.
 - EXTYP_NO
 - The excitation type of solver entity written out in the .exc solver deck file.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - INPUTLOAD_VALUE
 - The value of the input load.
 - INPUTOPTION
 - The input option for excitation load.
 - internalid
 - internalname
 - The internal name of the entity.
 - LINEAR_VAL
 - The value of the linear frequency bandwidth.
 - LOG_VAL
 - The value of the logarithmic frequency bandwidth.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - REVERBERANT_VARIABLE
 - The type of reverberant excitation load.
 - SCALETYPE
 - The scale of the excitation load.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2021.2
