perturbations
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - config
 - The configuration of the entity.
 - CORLGRP
 - The correlation group number.
 - definedentity
 - True if the entity is defined, false otherwise.
 - F_LCID
 - The ID of the curve defining the stochastic distribution.
 - F_R1
 - The real value defining the stochastic distribution R1.
 - F_R2
 - The real value defining the stochastic distribution R2.
 - F_R3
 - The real value defining the stochastic distribution R3.
 - ICOR
 - The correlation between the yield stress and failure strain scaling.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - IRNG
 - The flag for random number generation.
 - LCID
 - moduleid
 - The module ID of the entity.
 - MTYPE
 - The material type.
 - name
 - The name of the entity.
 - NUM_BEG
 - The location of the first variation in the history variables for a user material.
 - NUMV
 - The number of variations for a user material.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - PID
 - The ID of the component (*PART) entity.
 - PID_TYP
 - The flag for the PID type.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - PSID
 - The ID of the set (*SET_PART).
 - R1
 - The real value defining the stochastic distribution.
 - R2
 - R3
 - S_LCID
 - S_R1
 - S_R2
 - S_R3
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - Type
 - The type of the perturbation entity.
 - VAR_F
 - The variation type for scaling failure strain.
 - VAR_S
 - The variation type for scaling the yield stress.
 - VARTYP
 - The variation type for scaling the material property.
Version History
2022
