axisymmetries
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - axisx
 - The x coordinate of the axis.
 - axisxpoint
 - The x coordinate of a point on the axis.
 - axisy
 - The y coordinate of the axis.
 - axisypoint
 - The y coordinate of a point on the axis.
 - axisz
 - The z coordinate of the axis.
 - axiszpoint
 - The z coordinate of a point on the axis.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - id
 - The ID of the entity.
 - imprintlines
 - The IDs of the imprint lines.
 - imprintsolids
 - The IDs of the imprint solids.
 - imprintsurfaces
 - The IDs of the imprint surfaces.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - MainCrossSection
 - The ID of the main cross-section.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - NumImprintLines
 - The number of imprint lines.
 - NumImprintSurfaces
 - The number of imprint surfaces.
 - NumImprintSolids
 - The number of imprint solids.
 - NumSecondaryCrossSections
 - The number of secondary cross-sections.
 - NumUserSurfaces
 - The number of user surfaces.
 - NumVolumeGeometries
 - The number of surfaces.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - Part
 - The part ID of the entity.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - SecondaryCrossSections
 - The IDs of the secondary cross-sections.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - UserSurfaces
 - The IDs of the user surfaces.
 - volumegeometries
 - The IDs of the surfaces.
Version History
2022.1
