clearances
Unless otherwise specified, data names are accessible in level 3 only.
Most of the information for a card is contained in the attributes owned by the card.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
cardimage
The name of the assigned card image.
Type: string
cardimagetype
The type of the assigned card image.
Type: string
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
601 – ADVC $SubordinateNodeClearance
contactpairid
Specifies the Contact pair ID.
Type: entity
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
nodeclearance
Specifies the clearance to be applied on a node.
Type: double
nodeid
Specifies the node on which clearance is specified.
Type: entity
nodesetclearance
Specifies the clearance to be applied on a node group.
Type: double
nodesetid
Specifies the node group on which the clearance is specified.
Type: entity
numberofnodeclearance
Specifies the number of clearances specified on the nodes.
Type: integer
numberofnodesetclearance
Specifies the number of clearances specified on the node groups.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
status
The status of the entity.
Type: integer
Version History
2021.2
