interfacelinkings
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - color
 - The 1-64 color of the entity.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - entityid
 - The node ID or node set ID to be moved by the interface file. This is supported for config 101, 102 and 105.
 - filename
 - The name of the file where the component data will be writen when config=104.
 - fx
 - The ID of a *DEFINE_FUNCTION which determines the X direction displacement scale factor when config=105.
 - fy
 - The ID of a *DEFINE_FUNCTION which determines the Y direction displacement scale factor when config=105.
 - fz
 - The ID of a *DEFINE_FUNCTION which determines the Z direction displacement scale factor when config=105.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - interfaceid
 - The interface ID in the interface file. This is supported for config 101 and 102.
 - interfaceidlist
 - The list of interface IDs in the interface file. This is supported for config 103.
 - internalname
 - The internal name of the entity.
 - localflag
 - The flag to specify the local option when config=105.
 - locnode
 - The ID of the local node for transforming displacements when config=105.
 - locsystem
 - The ID of the local system for transforming displacements when config=105.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - segmentids
 - The segment sets to be moved by the interface file. This is supported for config 103.
 - segmentidsmax
 - The maximum number of segments referred.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - usecordinate
 - A flag to indicate the use of the coordinate system in the linking file during displacement transformation when config=105.
 - usenode
 - A flag to indicate the use of the node displacement in the linking file during displacement transformation when config=105.
Version History
2019
2019.1 - Added new data name filename.
2020 - Added new data name color_rgb.
2020.1 - Added new config values 104 and 105 and entityid support for config 105. Added new data names fx, fy, fz, localflag, locnode, locsystem, solverkeyword, usecordnate and usenode.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
