explorations
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- desvarlist
- The list of associated design variables.
- desyncflag
- Flag to mark an evaluated exploration as desynchronized from its results, if its design variables or responses data are modified. Valid for hm_getvalue query only.
- explorationlabel
- The label, used for the approach folder name.
- explorationtype
- 1 - Design of experiments
- explorationtypename
- The name of the exploration type. Valid for hm_getvalue query only.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- isactive
- True if the exploration is active. Valid for hm_getvalue query only.
- location
- The location of the exploration.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- optimizationname
- The name of the optimization. Valid for hm_getvalue query only.
- optimizationtype
- 1 - Gauge optimization
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- parentid
- The ID of the parent exploration. Used for DOE/optimization verification runs.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- responselist
- The list of associated responses.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- studyid
- The ID of the study where the exploration is defined.
- varname
- The name of the variable. Valid for hm_getvalue query only.
Version History
2020
2020.1 - Added new data name solverkeyword.
2021 - Added new data names desyncflag, explorationlabel, parentid and studyid.
2021.1 - Added new explorationtype value 3 and new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
