morphconstraints
Unless otherwise specified, data names are accessible in level 3 only.
- active
- The morph constraint active flag 0/1.
- attributesmax
- The number of attributes owned by this entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- nnode
- The number of constrained nodes.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- type
- The type of morph constraint.
- 0 - fixed
- 1 - vector
- 2 - line
- 3 - plane
- 4 - surface
- 5 - mesh
- 6 - fixed with stretching
- 7 - cluster
- 8 - smooth
- 9 - cluster with stretching
- 11 - vector with limit
- 12 - line with limit
- 13 - plane with limit
- 14 - surface with limit
- 15 - mesh with limit
- 20 - tangency
- 30 - model
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
