seamsubsystems
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - color
 - The 1-64 color of the entity.
 - config
 - The configuration of the entity.
 - color_rgb
 - The RGB color of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - SUBS_ID
 - The ID of the SEAMSubsytem solver entity.
 - SUBS_ELEM_ID
 - The element ID of the SEAMSubsytem solver entity.
 - SUBS_ELEM_TYPE
 - The element type of the SEAMSubsytem solver entity.
 - SUBS_FL_CLONG
 - The speed of sound in the fluid.
 - SUBS_FL_DENSITY
 - The fluid material density.
 - SUBS_FL_MAT
 - The fluid material of the SEAMSubsytem solver entity.
 - SUBS_FL_THICKNESS
 - The thickness of the fluid material.
 - SUBS_MATDATA1
 - The material data 1 of the SEAMSubsytem solver entity.
 - SUBS_MATDATA2
 - The material data 2 of the SEAMSubsytem solver entity.
 - SUBS_MATDATA3
 - The material data 3 of the SEAMSubsytem solver entity.
 - SUBS_MATDATA4
 - The material data 4 of the SEAMSubsytem solver entity.
 - SUBS_MATDATA5
 - The material data 5 of the SEAMSubsytem solver entity.
 - SUBS_MATDATA6
 - The material data 6 of the SEAMSubsytem solver entity.
 - SUBS_MATTYPE
 - The material type of the SEAMSubsytem solver entity.
 - SUBS_OPTION
 - The options for the SEAMSubsytem solver entity.
 - SUBS_SECTIONSIZE
 - The section size of the SEAMSubsytem solver entity.
 - SUBS_SHAPESIZE
 - The shape size of the SEAMSubsytem solver entity.
 - SUBS_TYPE
 - The type of the SEAMSubsytem solver entity.
Version History
2021.2
