mbplanes
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - AXglobal
 - The global x-coordinate of the mbplane origin.
 - AXlocal
 - The x-coordinate of the mbplane origin in the owning multibody's coordinate system.
 - AYglobal
 - The global y-coordinate of the mbplane origin.
 - AYlocal
 - The y-coordinate of the mbplane origin in the owning multibody's coordinate system.
 - AZglobal
 - The global z-coordinate of the mbplane origin.
 - AZlocal
 - The z-coordinate of the mbplane origin in the owning multibody's coordinate system.
 - BXglobal
 - The global x-coordinate of the mbplane x-axis.
 - BXlocal
 - The x-coordinate of the mbplane x-axis in the owning multibody's coordinate system.
 - BYglobal
 - The global y-coordinate of the mbplane x-axis.
 - BYlocal
 - The y-coordinate of the mbplane x-axis in the owning multibody's coordinate system.
 - BZglobal
 - The global z-coordinate of the mbplane x-axis.
 - BZlocal
 - The z-coordinate of the mbplane x-axis in the owning multibody's coordinate system.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - CXglobal
 - The global x-coordinate of the mbplane y-axis.
 - CXlocal
 - The x-coordinate of the mbplane y-axis in the owning multibody's coordinate system.
 - CYglobal
 - The global y-coordinate of the mbplane y-axis.
 - CYlocal
 - The y-coordinate of the mbplane y-axis in the owning multibody's coordinate system.
 - CZglobal
 - The global z-coordinate of the mbplane y-axis.
 - CZlocal
 - The z-coordinate of the mbplane y-axis in the owning multibody's coordinate system.
 - definedentity
 - True if the entity is defined, false otherwise.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - moduleid
 - The module ID of the entity.
 - multibody
 - A pointer to the owning multibody.
 - multibodyid
 - The ID of the owning multibody.
 - name
 - The name of the entity.
 - origin
 - The global origin coordinates. Valid for hm_getvalue query only.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - type
 - The solver dependent type code for the entity.
 - xaxis
 - The global x-axis coordinates. Valid for hm_getvalue query only.
 - yaxis
 - The global y-axis coordinates. Valid for hm_getvalue query only.
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
