optidscreens
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- autobuck
- BUCK - Turn on the buckling adjustment
- autolevel
- The normalized threshold value for Auto, with values ranging from 1-5 (ON), and 0 (OFF).
- autotoggle
- 0 - Auto off
- cfailuremaxc
- The maximum number of constraints to be retained for Cfailure.
- cfailurethreshold
- The normalized threshold value for Cfailure.
- cfailuretoggle
- 0 - CFailure off
- cogmaxc
- The maximum number of constraints to be retained for Cog.
- cogthreshold
- The normalized threshold value for Cog.
- cogtoggle
- 0 - Cog off
- CompMaxc
- Maximum number of constraints to be retained for Comp.
- CompThreshold
- Normalized threshold value for Comp.
- CompToggle
- Comp toggle on (1) and off (0) state.
- configname
- The solver name of the entity. Valid for hm_getvalue query only.
- cstrainmaxc
- The maximum number of constraints to be retained for Cstrain.
- cstrainthreshold
- The normalized threshold value for Cstrain.
- cstraintoggle
- 0 - Cstrain off
- cstressmaxc
- The maximum number of constraints to be retained for Cstress.
- cstressthreshold
- The normalized threshold value for Cstress.
- cstresstoggle
- 0 - Cstress off
- definedentity
- True if the entity is defined, false otherwise.
- DispMaxc
- Maximum number of constraints to be retained for Disp.
- DispThreshold
- Normalized threshold value for Disp.
- DispToggle
- Disp toggle on (1) and off (0) state.
- EquaMaxc
- Maximum number of constraints to be retained for Equa.
- EquaThreshold
- Normalized threshold value for Equa.
- EquaToggle
- Equa toggle on (1) and off (0) state.
- externalmaxc
- The maximum number of constraints to be retained for External.
- externalthreshold
- The normalized threshold value for External.
- externaltoggle
- 0 - External off
- forcemaxc
- The maximum number of constraints to be retained for Force.
- forcethreshold
- The normalized threshold value for Force.
- forcetoggle
- 0 - Force off
- fracclmaxc
- The maximum number of constraints to be retained for Fracceleration.
- fracclthreshold
- The normalized threshold value for Fracceleration.
- fraccltoggle
- 0 - Fracceleration off
- frdispmaxc
- The maximum number of constraints to be retained for Frdisplacement.
- frdispthreshold
- The normalized threshold value for Frdisplacement.
- frdisptoggle
- 0 - Frdisplacement off
- frequencymaxc
- The maximum number of constraints to be retained for Frequency.
- frequencythreshold
- The normalized threshold value for Frequency.
- frequencytoggle
- 0 - Frequency off
- frerpmaxc
- The maximum number of constraints to be retained for Frerp.
- frerpthreshold
- The normalized threshold value for Frerp.
- frerptoggle
- 0 - Frerp off
- frstrnmaxc
- The maximum number of constraints to be retained for Frstrain.
- frstrnthreshold
- The normalized threshold value for Frstrain.
- frstrntoggle
- 0 - Frstrain off
- frstrsmaxc
- The maximum number of constraints to be retained for Frstress.
- frstrsthreshold
- The normalized threshold value for Frstress.
- frstrstoggle
- 0 - Frstress off
- frvelomaxc
- The maximum number of constraints to be retained for Frvelocity.
- frcelothreshold
- The normalized threshold value for Frvelocity.
- frcelotoggle
- 0 - Frvelocity off
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- inertiamaxc
- The maximum number of constraints to be retained for Inertia.
- inertiathreshold
- The normalized threshold value for Inertia.
- inertiatoggle
- 0 - Inertia off
- internalid
- internalname
- The internal name of the entity.
- lamamaxc
- The maximum number of constraints to be retained for Lama.
- lamathreshold
- The normalized threshold value for Lama.
- lamatoggle
- 0 - Lama off
- massfracmaxc
- The maximum number of constraints to be retained for Massfrac.
- massfracthreshold
- The normalized threshold value for Massfrac.
- massfractoggle
- 0 - Massfrac off
- massmaxc
- The maximum number of constraints to be retained for Mass.
- massthreshold
- The normalized threshold value for Mass.
- masstoggle
- 0 - Mass off
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- strainmaxc
- The maximum number of constraints to be retained for Strain.
- strainthreshold
- The normalized threshold value for Strain.
- straintoggle
- 0 - Strain off
- StressMaxc
- Maximum number of constraints to be retained for Stress.
- StressThreshold
- Normalized threshold value for Stress.
- StressToggle
- 0 - Stress off
- volumefracmaxc
- The maximum number of constraints to be retained for Volumefrac.
- volumefracthreshold
- The normalized threshold value for Volumefrac.
- volumefractoggle
- 0 - Volumefrac off
- volumemaxc
- The maximum number of constraints to be retained for Volume.
- volumethreshold
- The normalized threshold value for Volume.
- volumetoggle
- 0 - Volume off
Version History
2017.1 - Added new data names autolevel, autotoggle, cfailuremaxc, cfailurethreshold, cfailuretoggle, cogmaxc, cogthreshold, cogtoggle, cstraingtoggle, cstrainmaxc, cstrainthreshold, cstressmaxc, cstressthreshold, cstresstoggle, externalmaxc, externalthreshold, externaltoggle, forcemaxc, forcethreshold, forcetoggle, fracclmaxc, fracclthreshold, fraccltoggle, frdispmaxc, frdispthreshold, frdisptoggle, freqtoggle frequencymaxc, frequencythreshold, frerpmaxc, frerpthreshold, frerptoggle, frstrnmaxc, frstrnthreshold, frstrsmaxc, frstrsthreshold, frstrstoggle, frevelomaxc, frevolothreshold, frevolotoggle, inertiamaxc, inertiathreshold, inertiatoggle, lamamaxc, lamathreshold, lamatoggle, massfracmaxc, massfracthreshold, massfractoggle, massmaxc, massthreshold, masstoggle, strainmaxc, strainthreshold, straintoggle, volumefracmaxc, volumefracthreshold, volumefractoggle, volumemaxc, volumethreshold and volumetoggle.
2020 - Added new data name autobuck.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
