elastic
- attributesmax
- The number of attributes owned by this entity.
- beamsect_nonstandard
- The string name of the beamsection type, or blank if not defined.
- collector
- Pointer to the collector that owns the element.
- config
- The configuration of the entity.
- dt_field
- Table containing the tessellation information.
- dt_dataset
- Table containing the solver information (material, functions, and so on).
- Fillcolor
- The color the beam section uses for display of solid regions.
- Flags
- The optimization flag.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- Linecolor
- The color the beam section uses for display of lines.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- OrientationOrigin0
- The y component of the beam section origin.
- OrientationOrigin1
- The z component of the beam section origin.
- OrientationVector0
- The y component of the beam section orientation vector.
- OrientationVector1
- The z component of the beam section orientation vector.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- setid
- The ID of the beam section collector owning the entity.
- sketch
- Pointer to the sketcher that defines the beam section.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- TorsionFactor
- The torsion factor of the beam section.
- WarpingFactor
- The warping factor of the beam section.
Version History
2020.1 - Added new data name solverkeyword.
2021.2 - Added new data names internalname and solvername.
2022.1 - Added new config value 4 with new data names dt_field, dt_dataset, and sketch.
