topography
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- attributesmax
- The number of attributes owned by this entity.
- autobead
- Indicates that AUTOBEAD of OSSmooth is used to interpret the results as one or two level beads.
- basethickness
- The x component of the vector specifying the draw direction.
- boundaryskip
- Flag to indicate setting of the SKIP parameter.
- bufferzone
- 2 if buffer zone exists, 1 otherwise.
- componentlist
- The list of property IDs associated with the designvar (pointer value is property ID).
- componentlistmax
- The number of properties referenced by the designvar.
- config
- The configuration of the entity.
- configname
- The solver keyword for the designvar. Valid for hm_getvalue query only.
- ddvalid
- The ID of the DDVAL entry that provides a set of discrete values.
- definedentity
- True if the entity is defined, false otherwise.
- delxv
- The z component of the vector specifying the draw direction.
- designable
- Flag to indicate the draw direction .
- designthickness
- The y component of the vector specifying the draw direction.
- drawangle
- The draw angle in degrees.
- drawdirection
- The x, y and z components of the draw direction. Valid for hm_getvalue query only.
- drawdirectiontoggle
- Flag to activate draw direction.
- drawdirectionx
- The x components of the draw direction. Valid for hm_getvalue query only.
- drawdirectiony
- The y components of the draw direction. Valid for hm_getvalue query only.
- drawdirectionz
- The z components of the draw direction. Valid for hm_getvalue query only.
- drawdirectiontype
- The type of the draw direction. Valid for hm_getvalue query only.
- drawheight
- The draw height.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- layer
- The number of layers, 1 (default) or 2.
- lowerbound
- The lower bound of the variables controlling grid movement.
- maxwidth
- The maximum bead. This can be used to prevent the formation of large beads. It should be at least twice the value of the minimum bead width.
- minheightratio
- The minimum height ratio to be considered as bead.
- minimumwidth
- The bead minimum width.
- moduleid
- The module ID of the entity.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- patterngroupingtype
- The pattern grouping type.
- patterngroupingsubtype
- The pattern grouping sub type.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- property
- The type of property referenced by the designvar.
- propertylist
- propertytypename
- The type name of the property referenced by the designvar.
- reflective
- Theflag for reflection in pattern grouping.
- remesh
- The element size for remeshing.
- setlist
- The SET identification number referring to the set of elements.
- shapedesignvariable
- A non-zero value indicates that the property type is DVGRID, and the value is the designvar ID for the set of DVGRIDs.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- tgboundaryskip
- The value of the SKIP parameter.
- tganchorpointtriple
- The x-y-z coordinate of the anchor node.
- tgfirstgridtriple
- The x-y-z coordinate of the first grid for pattern repetition coordinate system .
- tgsecondgridtriple
- The x-y-z coordinate of the second grid for pattern repetition coordinate system .
- thresh
- The threshold value in autobead. Default 0.3 [0.0, 1.0].
- topography_bufferzone
- True if buffer zone exists, false otherwise.
- topographymainptr
- The DTPL identification number for a main pattern definition.
- topographymainsecondary
- 0 - None
- upperbound
- The upper bound on variables controlling grid movement.
- yorder
- 1 if bounds are specified on DTPG card, 0 otherwise.
- ytype
- Flag indicating if designvar is main (1) or secondary (2).
- zerob
- Indicates whether the width control is applied to the beads with zero height (YES or NO).
Pattern Grouping Variables (applicable if PATRN is specified on DTPG card)
- anchorpointid
- The ID of the anchor node.
- firstgrid
- The ID of the first grid node.
- secondgrid
- The ID of the second grid node.
- type
- xorder
- The number of repetitions for cyclic symmetry UCYC.
- $TPG_BeadBoundarySkip
- Boundary skip indicating to leave certain nodes out of the design domain.
- $TPG_BeadBufferZone
- Establishes a buffer zone between elements in the design domain and elements outside the design domain.
- $TPG_BeadString
- Indicates whether DTPG card is defined for PSHELL, PCOMP, or DVGRID.
- $TPG_DRAW_DIR
- Draw direction.
- $TPG_MainDesvar
- DTPL identification number for a main pattern definition.
- $TPG_SecondGridX
- The x coordinate of the second point.
- $TPG_SecondGridY
- The y coordinate of the second point.
- $TPG_SecondGridZ
- The z coordinate of the second point.
- $TPG_SymmetryAnchorX
- The x coordinate of the anchor point.
- $TPG_SymmetryAnchorY
- The y coordinate of the anchor point.
- $TPG_SymmetryAnchorZ
- The z coordinate of the anchor point.
- $TPG_SymmetryNormalX
- The x coordinate of the first point.
- $TPG_SymmetryNormalY
- The y coordinate of the first point.
- $TPG_SymmetryNormalZ
- The z coordinate of the first point.
Pattern Repetition Variables (applicable if MAIN/SECONDARY is specified in DTPL card)
- $TPL_RptnAnchorNodeId
- $TPL_RptnAnchorX
- The x coordinate of the first grid node.
- $TPL_RptnAnchorY
- The y coordinate of the first grid node.
- $TPL_RptnAnchorZ
- The z coordinate of the first grid node.
- $TPL_RptnFirstGridId
- $TPL_RptnFirstGridX
- $TPL_RptnFirstGridY
- $TPL_RptnFirstGridZ
- $TPL_RptnScaleX
- The x direction scale factor.
- $TPL_RptnScaleY
- The y direction scale factor.
- $TPL_RptnScaleZ
- The z direction scale factor.
- $TPL_RptnSecondGridId
- $TPL_RptnSecondGridX
- The x coordinate of the second grid node.
- $TPL_RptnSecondGridY
- The y coordinate of the second grid node.
- $TPL_RptnSecondGridZ
- The z coordinate of the second grid node.
- $TPL_RptnSysFlag
- Returns 0 if no coordinate system is used in defining the pattern repetition, non-zero otherwise.
- $TPL_RptnSysId
- The ID of the pattern repetition coordinate system when $TPL_RptnSysFlag is non-zero.
- $TPL_RptnThirdGridId
- The ID of the third grid node.
- $TPL_RptnThirdGridX
- The x coordinate of the third grid node.
- $TPL_RptnThirdGridY
- The y coordinate of the third grid node.
- $TPL_RptnThirdGridZ
- The z coordinate of the third grid node.
Version History
2017.1 - Added new data names drawdirectiontoggle, patterngroupingtype, patterngroupingsubtype, reflective, tgboundaryskip, tganchorpointtriple, tgfirstgridtriple, tgsecondgridtriple, topography_bufferzone, topographymainptr, and topographymainsecondary.
2019 - Added new data names autobead, ddvalid, layer, maxwidth, minheightratio, remesh, setlist, thresh and zerob.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
