rigid
Unless otherwise specified, data names are accessible in level 3 only.
- attributesmax
- The number of attributes owned by this entity.
- centerx
- The x coordinate of the element centroid.
- centery
- The y coordinate of the element centroid.
- centerz
- The z coordinate of the element centroid.
- collector
- Pointer to the collector that owns the element.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- dofs
- The degrees of freedom, consisting of the values 1-6.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- length
- The length of the element.
- moduleid
- The module ID of the entity.
- node1
- Pointer to the independent node of the element.
- node2
- Pointer to the dependent node of the element.
- nodecount
- The number of nodes for the element. Valid for hm_getvalue query only.
- nodes
- The list of nodes for the element. Valid for hm_getvalue query only.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- type
- The solver dependent type code for the entity.
- typename
- The solver dependent type name for the entity.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
