tria6
Unless otherwise specified, data names are accessible in level 3 only.
- area
- The element area.
- aspect
- The element aspect ratio.
- attributesmax
- The number of attributes owned by this entity.
- centerx
- The x coordinate of the element centroid.
- centery
- The y coordinate of the element centroid.
- centerz
- The z coordinate of the element centroid.
- collector
- Pointer to the collector that owns the element.
- config
- The configuration of the entity.
- definedentity
- True if the entity is defined, false otherwise.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- internalid
- internalname
- The internal name of the entity.
- jacobian
- The element jacobian.
- longestaltitude
- The longest distance from a node to a non-adjoining edge.
- longestside
- The longest element edge length.
- maxangle
- The maximum interior angle.
- minangle
- The minimum interior angle.
- moduleid
- The module ID of the entity.
- node1 - node3
- Pointers to the element nodes.
- nodecount
- The number of nodes for the element. Valid for hm_getvalue query only.
- nodes
- The list of nodes for the element. Valid for hm_getvalue query only.
- normalx
- The x component of the element normal.
- normaly
- The y component of the element normal.
- normalz
- The z component of the element normal.
- poolid
- The pool number of the entity.
- poolname
- The pool name of the entity.
- property
- Pointer to the property assigned to the entity.
- propertyid
- The ID of the property assigned to the entity.
- propertyidflag
- 1 if a property is assigned directly to the entity, 0 otherwise.
- shortestaltitude
- The shortest distance from a node to a non-adjoining edge.
- shortestside
- The shortest element edge length.
- skew
- The element skew angle.
- solver_id
- The solver ID of the entity.
- solverkeyword
- The name of the solver keyword.
- solvername
- The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
- type
- The solver dependent type code for the entity.
- typename
- The solver dependent type name for the entity.
- warpage
- The element warpage.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
