AERO
Bulk Data Entry Defines basic parameters for dynamic aeroelasticity.
AERO | ACSID | VELOCITY | REFC | RHOREF | SYMXZ | SYMXY |
AERO | 10 | 4000.0 | 100.0 | 0.0003 | 1 | -1 |
ACSID | Aerodynamic coordinate system identification. Default = 0 (Integer ≥ 0) |
VELOCITY | Velocity for recovery of aerodynamic force data and for
calculating the reduced frequency. No default (Real > 0.0) |
REFC | Reference length for reduced frequency. No default (Real > 0.0) |
RHOREF | Reference density. No default (Real > 0.0) |
SYMXZ | Symmetry key for the aero coordinate X-Z plane. If case
control entry AESYMXZ is specified,
this field is ignored.
SYMXY | Symmetry key for the aero coordinate X-Y plane to simulate ground
effects. If case control entry AESYMXY
is specified, this field is ignored.
- This entry is mandatory for dynamic aeroelastic analysis. Only a single AERO entry is allowed.
- The ACSID field should reference a rectangular coordinate system. Flow is in the positive X-direction (T1).
