Bulk Data Entry Defines a multibody solver variable which can be
referred to by multiple expressions.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MBVAR |
VID |
EXPR |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| MBVAR |
3 |
IMPACT(Dz(30301020,30302040),VZ(30301020,30302040),0.0,4 |
00,1.0,0.5,0.000) |
| Field |
Contents |
SI Unit Example |
| VID |
Variable
identification number. (Integer > 0)
| EXPR |
Character string
expression. The expression can spawn multiple lines. The
continuation lines will start from the second column. Refer to
Function Expressions. |
- The variable ID can be referenced by
VARVAL(VID) in multiple expressions in the model.
