NSGEADD
Bulk Data Entry Defines non-structural material damping as the sum of the sets listed.
NSGEADD SID S1 S2 S3 S4 S5 S6 S7
  S8 S9 S10 etc.
NSGEADD 5 10 20
SID Non-structural material damping set identification number.
No default (Integer > 0)
S# Identification number of non-structural material damping sets defined via NSGE and NSGE1 entries.
No default (Integer > 0, SID ≠ S#)
  1. Non-structural material damping in this format must be selected by the NSGE Subcase Information selector.
  2. No S# may be the identification number of a non-structural material damping set defined by another NSGEADD entry.
  3. NSGEADD entries take precedence over NSGE and NSGE1 entries. If both/all have the same SID, only the NSGEADD entry will be used.
  4. Optimization is currently not supported with non-structural damping.
