MEFFSET
Bulk Data Entry This entry is used to group element sets for which MEFFMASS output is desired in HyperMesh set based format.
MEFFSET | ID | ||||||||
+ | SETID1 | SETID2 | SETID3 | SETID4 | etc. | ||||
+ | etc. | SETIDi | etc. |
+ | 101 | 102 | 103 | 104 | 105 |
ID | Unique identification
number. This ID must match the SET in MEFFMASS definition. No default (Integer > 0) |
SETIDi | Element set ID. No default (Integer > 0) |
- MEFFSET is only applicable with the MEFFMASS entry when output is desired in the form of element sets.
- The output is printed to the .out file and also to an .effmass file ASCII format file.
