DMGEVO
Bulk Data Entry Defines the damage evolution.
DMGEVO DMGEVOID TYPE SHAPE
  MMXFM ALPHA W1 W2 W3
Example (Damage based on energy with power law mixing)
DMGEVO 24 COHENRG EXP
  1 1.2 2.0 5.0 5.0
Example (Damage based on energy with B-K form mixing)
DMGEVO 57 COHENRG LIN
  2 1.5 24.0 50.0
Example (Damage based on energy no mode mixing)
      20.0
Example (Damage based on opening)
DMGEVO 1 COHDISP EXP
    2.0 20.0
Example (Ductile damage based on displacement)
DMGEVO 1 DISP EXP
    2.0 0.5
Example (Ductile damage based on energy)
DMGEVO 1 ENERGY LIN
    20.0
DMGEVOID Damage evolution identification number.
No default (Integer > 0)
TYPE Damage evolution type.
COHDISP
Damage index evaluated by displacement for cohesive elements.
COHENRG
Damage index evaluated by energy dissipated for cohesive elements.
DISP
Damage index evaluated by displacement for solid and shell elements (ductile damage).
ENERGY
Damage index evaluated by energy for solid and shell elements (ductile damage).
No default
SHAPE Profile shape of the traction-opening curve in the descending part.
LIN (Default)
Linear shape.
EXP
Exponential shape.
MMXFM Mode mixed form (only for TYPE = COHENRG).
Blank (Default)
Modes are not mixed.
1
Power law form.
2
Benzeggah-Kenane form.
ALPHA When TYPE = COHDISP with SHAPE = EXP, it is the exponent for the traction-separation curve.
When TYPE = COHENRG with MMXFM = 1, it is the exponent for the mixing formula.
When TYPE = COHENRG with MMXFM = 2, it is the mixing coefficient.
When TYPE = DISP or ENERGY with SHAPE = EXP, it is the exponent for the stress degrading curve.
No default (Real > 0)
W1. W2, W3 Material curve parameters.
When TYPE=COHDISP/DISP, only W1 is required.
W1
The separation evaluated from damage initiation to failure.
W2 and W3
Must be blank.
When TYPE=COHENRG, the parameters are the energies that can be dissipated in pure normal and pure shear separation.
W1
Energy dissipated in Mode I.
W2
Energy dissipated in Mode II.
W3
Energy dissipated in Mode III.
When TYPE=COHENRG with MMXFM= Blank.
W1
Energy dissipated.
W2 and W3
Must be blank.
When TYPE=DISP
W1
Equivalent plastic displacement from damage initiation to failure.
W2 and W3
Must be blank.
When TYPE=ENERGY
W1
Energy dissipated from damage initiation to failure.
W2 and W3
Must be blank.
[m] for TYPE=COHDISP/DISP
[Nm] or [Jm2] for TYPE=COHENRG/ENERGY
  1. The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED, DMGINI, and DMGEVO entries.
  2. The support information for Damage evolution is as follows:
    Analysis Types Criterion
    Nonlinear Static Analysis, Nonlinear Transient Analysis DISP, ENERGY, COHDISP, COHENRG
    Explicit Dynamic Analysis DISP, ENERGY
    Element Types Criterion
    Regular Shell and Solid Elements DISP, ENERGY
    Cohesive Elements COHDISP, COHENRG
  3. For additional information about cohesive elements, refer to Cohesive Zone Modeling in the User Guide.
