Bulk Data Entry Defines units for multibody, component mode
synthesis (flexible-body preparation), and Explicit Dynamic Analysis sequences.
- PARAM, WTMASS is ignored for the
multibody and component mode synthesis (flexible-body preparation) solution
sequences. Unit data for these solution sequences is supplied on the
DTI,UNITS Bulk Data Entry.
- This DTI,
UNITS Data Entry is the same as the UNITS entry.
- If the units defined on the
DTI,UNITS entry are not consistent,
mass unit is ignored, only force, length, and time units are considered in
Explicit Dynamic Analysis subcases.
- This card is represented as a control
card in HyperMesh.
