Bulk Data Entry Indicates the beginning of data that is used to describe a specific
entity (or entities) for inclusion in a model. The BEGIN entry is used in
conjunction with the END entry to define the data required for a specific
entity.
- The BEGIN and
END Bulk Data Entries are used in conjunction to define an
entity within the full model.
- The INCLUDE entry,
similar to almost any other Bulk Data Entry, is allowed between
BEGIN and END entries. However,
BEGIN and END should exist in the same
file.
- Models are often defined in separate files,
and the block (BEGIN - END) contains only
INCLUDE entries. It is possible to duplicate a single part by
including the same file(s) in different
BEGIN-END blocks.
- In case of partitioned (PART)
superelement (TYPE = SUPER), the Bulk Data
Section can be divided into separate sections for each PART. This division is
accomplished by using the BEGIN SUPER entry. These separate
sections of the Bulk Data are self-contained and each section contains all
geometry, elements, properties, constraints and loading data for that component
of the model. Note that there is no entry to mark the ending of a
superelement.
- There can be multiple sections of arbitrary
beam data; one for each beam section.
- An example set of data for the definition of
an arbitrary beam section is as
follows:
BEGIN,HYPRBEAM,SQUARE
GRIDS,1,0.0,0.0
GRIDS,2,1.0,0.0
GRIDS,3,1.0,1.0
GRIDS,4,0.0,1.0
CSEC2,10,100,1,2
CSEC2,20,100,2,3
CSEC2,30,100,3,4
CSEC2,40,100,4,1
PSEC,100,1000,0.1
END,HYPRBEAM
