RSPEC
Bulk Data Entry Specifies directional combination method, modal combination method, excitation direction(s), response spectra and scale factors for Response Spectrum Analysis.
| RSPEC | RID | DCOMB | MCOMB | CLOSE | |||||
| DTISPEC1 | SCALE1 | X11 | X12 | X13 | |||||
| DTISPEC2 | SCALE2 | X21 | X22 | X23 | |||||
| DTISPEC3 | SCALE3 | X31 | X32 | X33 |
Example 1
| RSPEC | 35 | ALG | SRSS | 1.0 | |||||
| 7 | 1.3 | 0.5 | 0.5 | -1. |
Example 2
| RSPEC | 35 | SRSS | CQC | 0.0 | |||||
| 7 | 1.3 | 0.5 | 0.5 | -1. | |||||
| 4 | 2.0 | -2 | -0.0 | -1. | |||||
| 2 | 17. | 0.5 | -2.5 | -1. |
| RID | RSPEC
identification number. Must be unique. No default (Integer > 0) |
| DCOMB | Directional combination
method.
| MCOMB | Modal combination
method.
| CLOSE | Modal frequency closeness
parameter. 2 Default = 1.0 (Real ≥ 1.0) |
| DTISPECi | Response spectrum
reference. Identification number of the DTI,SPECSEL entry. No default (Integer > 0) |
| SCALEi | Scale factor for
excitation. No default (Real <> 0.0) |
| Xij | Components of a vector representing ground excitation i, j = 1..3 |
- DTISPEC2/SCALE2/X21/X22/X23 and DTISPEC3/SCALE3/X31/X32/X33 are optional ground excitations for multi-directional excitation. The directions of excitation have to be orthogonal to each other and will be reported as error otherwise.
- When MCOMB =
SRSS or NRL, natural frequencies that are
close will be summed by the ABS method. The close frequencies
are determined using the inequality.
(1) F(i+1)<CLOSE*F(i)Where, F(i) and F(i+1) are successive natural frequencies.
Then, they are combined with other modal contributions in accordance with the specified MCOMB option. Since natural frequencies are in ascending order, CLOSE values should be greater than or equal to 1.0.
- Refer to Response Spectrum Analysis in the User Guide for more details.
