PARAM, XB
Bulk Data Entry This parameter can be used to print nodal coordinate information in the local coordinate system in an additional field/column in the .h5 file.
Parameter Values Description
XB <YES, NO>
YES
Nodal coordinates are output in an additional field/column (XB) in the local coordinate system as well as the global coordinate system (column X) in the .h5 file.
NO (Default)
Nodal coordinates are output only with respect to the global coordinate system (column X).
  1. For more information, refer to HDF5 Data Types in the User Guide.
