*CE_BoltAutoCreateFromAttachments
Creates bolt connectors from attachments.
*CE_BoltAutoCreateFromAttachments mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark of attachments to create bolt connectors from. Valid values are 1 and 2.
- string_array
- The ID of the array created using *createstringarray, which
contains the additional input strings. Must be set to 1. Valid strings are:
- ce_config_name=<name>
- The name of the bolt config.
- maxdiameter=<value>
- The maximum hole diameter to find (default 25.0).
- mindiameter=<value>
- The minimum hole diameter to find (default 0.0).
- only2layer=<value>
- The number of attachments per bolt (default 0).
- tolerance=<value>
- The tolerance to use for attachment pair searches (default 50).
- number_of_strings
- The number of strings in string_array.
Examples
*createmark attachments 1 "attach_200_229" "attach_36_51"
*createstringarray 2 "tolerance=25" "ce_config_name=bolt (general)"
*CE_BoltAutoCreateFromAttachments 1 1 2Errors
# Handle error
}Version History
2020
