*linecombine
Combines two free lines into one.
*linecombine line_id1 line_id2 smooth
HyperMesh Tcl Modify Command
- line_id1
- The ID of the first free line.
- line_id2
- The ID of the second free line.
- smooth
- A flag that determines whether the lines should be combined with a straight line segment (0) or a smooth line segment (1) if the end points of the lines are not coincident.
To combine lines 10 and 20 with a smooth segment:
*linecombine 10 20 1
# Handle error
