*assemblyremovemark
Removes the components within a mark from the components contained in an assembly mark.
*assemblyremovemark assemblymark entitytype entitymark
HyperMesh Tcl Modify Command
assemblymark
The ID of the assembly mark from which you wish to remove assemblies, components, or multibodies.
entitytype
The type of entity contained on the entitymark: assemblies, components, or multibodies.
entitymark
The ID of the mark to be removed from the assembly.
Examples
To remove component 14 from assembly 2:
*createmark assemblies 2 2
*createmark components 1 14
*assemblyremovemark 2 components 1
