*linear1delements_byprojections
Creates 1D elements.
*linear1delements_byprojections mark_id1 mark_id2 config type density node1 node2
HyperMesh Tcl Modify Command
Creates 1D elements between selected elements.
- mark_id1
- The ID of the mark containing the elements defining the first boundary. Valid values are 1 and 2.
- mark_id2
- The ID of the mark containing the elements defining the second boundary. Valid values are 1 and 2.
- config
- The configuration of the 1D elements.
- type
- The type of the 1D elements.
- density
- The number of 1D elements created between the elements on mark_id1 and mark_id2.
- node1
- The ID of the first node defining the projection direction as node1-node2. If the value is specified as 0, the element normal is used.
- node2
- The ID of the second node defining the projection direction as node1-node2. If the value is specified as 0, the element normal is used.
Examples
*createmark elems 1 5 6 7
*createmark elems 2 10 23 34
*linear1delements_byprojections 1 2 61 2 4 0 0Errors
# Handle error
}Version History
2023
