*metadatamarkentityidtype
Creates entity ID type metadata on the specified mark of entities.
*metadatamarkentityidtype entity_type mark_id name entity_type_2 value
HyperMesh Tcl Modify Command
- entity_type
- The type of entities contained on the mark.
- mark_id
- The ID of the mark containing the entities to which the metadata will be added. Valid values are 1 and 2.
- name
- The name by which the metadata will be referenced.
- entity_type_2
- The type of entity which the metadata references.
- value
- The entity ID value assigned to the metadata.
To add metadata named Surface with surface 100 to elements 1-100:
*createmark elems 1 1-100
*metadatamarkentityidtype elems 1 "Surface" surfs 100
# Handle error
