*writefile
Saves a binary HyperMesh database.
*writefile filename do_not_write_facets
HyperMesh Tcl Modify Command
This command saves a binary HyperMesh database.
- filename
- The full path and filename of the database to save. If this file already exists, HyperMesh prompts to overwrite the file.
- do_not_write_facets
- 0 - Geometry facets are written to the file, leading to a larger file but faster load time.
Examples
To save the model to a file named mymodel.hm in the current working directory:
*writefile mymodel.hm 0
To save the model to a file named C:/mymodel.hm:
*writefile C:/mymodel.hm 0
To overwrite an existing file named C:/mymodel.hm:
hm_answernext yes
# Handle error
}Version History
2019 - The behavior of the do_not_write_facets option has changed. Previously, entering a value of 1 did not write facets, but now value 1 is the same as value 0. A new value 2 is now used to not write facets.
