*elementtestconnectivity
Tests elements for whether or not they are connected in any one of a number of common but invalid ways and puts those that are on the specified outputmark.
*elementtestconnectivity entities markmask outputmark dimension
HyperMesh Tcl Modify Command
- entities
- The entity types to be checked. Currently, elements is the only allowable option.
- markmask
- The mark that contains the elements to test.
- outputmark
- The mark where HyperMesh should put the elements that fail the test.
- dimension
- A code telling to measure the dimension of:
- 1 - Measure 1D elements.
- 2 - Measure 2D elements.
- 4 - Measure 3D elements.
*createmark elements 1 "displayed"
*createmark elements 2
*elementtestconnectivity elements 1 2 1
Version History
2017.1 - Now flags mid-side nodes connected to corner nodes as invalid.
