*marksmoothsolids
Applies a simple smoothing algorithm to reposition the interior floating nodes in a mesh of solid elements, attempting to moderate variations in element size and quality.
*marksmoothsolids mark iterations
HyperMesh Tcl Modify Command
- mark
- The mark of the solid elements.
- iterations
- The number of times to apply the algorithm.
To smooth some elements for 10 iterations:
*createmark elements 1 7 8 9 11 12 13 17 54
*marksmoothsolids 1 10
The *createmark() command is required.
None.
