*CE_PositionConnectors
Positions connectors to the middle point or back to the source location.
*CE_PositionConnectors mark_id center_source upon_state
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the connectors to modify. Valid values are 1 and 2.
- center_source
- 0 - Position to center
- upon_state
- 0 - Unrealize
To position connectors to middle point and unrealize them:
*createmark connectors 1 all
*CE_PositionConnectors 1 0 0
# Handle error
Version History
2019.1
