*morphsymmetrycreateaxis
Creates symmetry dependent on system.
*morphsymmetrycreateaxis name sysptr domaintype markdomain enforce multilat type ucyc orient mv
HyperMesh Tcl Modify Command
- name
- Name of symmetry.
- sysptr
- ID of system.
- domaintype
- Domains
- markdomain
- Domain mark number.
- enforce
- 0 = approximate
- multilat
- 0 = unilateral
- type
- Type of symmetry.
- ucyc
- Number of cycles for cyclical symmetry.
- orient
- 0 = default
- mv
- 0 = do not apply to morph volumes
*morphsymmetrycreateaxis "mirror" 2 DOMAINS 1 1 1 10 3 1 0
Creates a symmetry dependent on the specified system for the domains on the mark. The symmetry has the values given in ‘enforce’, ‘multilat’, type, ucyc, orient, and mv.
None.
