*manualsplit_applypatterns
Splits shell elements with specific patterns, and automatically splits attached 1Ds.
*manualsplit_applypatterns edge_split_count triplets
HyperMesh Tcl Modify Command
Pattern Name | Pattern ID | Image |
Quad0000 | 10 | |
Quad0000 | 85 | |
Quad0000 | 86 | |
Quad0000 | 89 | |
Quad1000 | 17 | |
Quad1000 | 59 | |
Quad1000 | 87 | |
Quad1010 | 15 | |
Quad1100 | 13 | |
Quad1110 | 66 | |
Quad1111 | 19 | |
Quad2000 | 72 | |
Quad2020 | 77 | |
Quad2200 | 73 | |
Quad2220 | 79 | |
Quad2222 | 78 | |
QuadN000 | 101 | |
QuadN0N0 | 103 | |
QuadNN00 | 102 | |
QuadNNN0 | 104 | |
QuadNNNN | 105 | |
Tria000 | 68 | |
Tria000 | 88 | |
Tria100 | 32 | |
Tria110 | 33 | |
Tria111 | 80 | |
Tria111 | 81 | |
Tria200 | 82 | |
Tria220 | 83 | |
Tria222 | 84 | |
TriaN00 | 106 | |
TriaNN0 | 107 | |
TriaNNN | 108 |
- edge_split_count
- The number of split points on element edges. Valid values are ≥ 0.
- triplets
- Uniquely determines a split pattern to be applied on a given element. This is a space separated and quoted list of triplets, with each triplet consisting of 3 colon separated values Ai:Bi:Ci. These values are:
Examples
*manualsplit_applypatterns 4 "100:106:2"
*manualsplit_applypatterns 1 "4:17:1 14:89:0 47:86:0 61:17:3"
# Handle error
Version History
2020
