*morphconvertmv
Converts the morph volumes on the mark to hexa elements or vice-versa.
*morphconvertmv ctype cmark han ord tan mode nauto
HyperMesh Tcl Modify Command
ctype
HYPERCUBES or ELEMS
cmark
Mark number of morph volumes or elements
han
0 - Do not create handles for morph volumes
1 - Create handles for morph volumes
ord
Order of morph volumes
tan
0 - No tangency
1 - Make neighboring morph volume edges continuously tangent
mode
0 - Morph volumes to hexas
1 - Hexas to morph volumes
nauto
0 - Do not register all nodes found inside morph volumes
1 - Register all nodes found inside morph volumes
*morphconvertmv HYPERCUBES 1 1 1 1 0 1
This command will either convert the morph volumes on the mark to hexa elements or convert the hexa elements on the mark to hypercubes with the given options for handles, order, tangency, and node registration.
Morph volumes will always get converted to second order hexa elements.
None.
