*facedeleteduplicates
Deletes duplicate faces.
*facedeleteduplicates mark tol
HyperMesh Tcl Modify Command
- mark
- The mark ID which contains the faces to compare for and delete duplicates.
- tol
- The tolerance used to find duplicate faces.
*createmark faces 1 2 4 7 14 23
*facedeleteduplicates 1 0.1 The *createmark() command is required.
