*loadsettypes
Sets the global load type variable.
*loadsettypes mark entities
HyperMesh Tcl Modify Command
mark
The mark which contains the loads to be updated.
entities
The type of load to change.
To set all of the displayed forces to type 5, and all of the displayed moments to type 6:
*loadtype (1,5)
sets new Forces (1) to type 5 but does not change existing ones
*loadtype (2,6)
sets new Moments (2) to type 6 (doesn’t change existing ones)
*createmark(loads,1) displayed
places all existing displayed loads into Mark1
*loadsettypes(1)
changes all the entities in Mark1 to use the types already defined for Forces (5) and Moments (6)
None.
