*setglobalply_option
Sets the ply/layer name to review.
*setglobalply_option entity_type mark_id ply_name only_orient normal_size color option
HyperMesh Tcl Modify Command
Sets the ply/layer name to review. The element ply direction of that ply will be plotted for each selected element with respect to the element (material) orientation. When review is complete, the command *vectorsoff must be run.
- entity_type
- The type of entity to review. Valid values are elements and properties.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- ply_name
- The name of the ply to review.
- only_orient
- 0 - The new x-element directions are shown as continuous gradient lines starting and ending on free edges.
- 1 - The new x-element directions are displayed as vectors starting from the element centroid.
- normal_size
- If only_orient=1, this defines the size of the displayed vectors.
- color
- The color of the vectors or lines. Valid values are 1-64.
- option
- Option for review customization. Valid values are:
- 1 - Abaqus rebar layer will be reviewed
To review the ply directions for the second ply named "ply45" for the displayed elements with blue vectors of size 3:
*createmark elems 1 displayed
*setglobalply_option elems 1 "ply45" 1 3 7 1
*vectorsoff
# Handle error
Version History
10-SA1-130
