*reversecontactsurfnormals
Change normals (inward to outward, vice versa) of contactsurf.
*reversecontactsurfnormals name elemmark indelems
HyperMesh Tcl Modify Command
Name
Name of the contactsurf being created.
Elemmark
Elements whose normal need to be reversed.
Indelems
Flag for reversing normals of all or individual elements of a contactsurf (0 = all elements and 1 = individual elements).
Reverse normals of contactsurf "test" for the elements on mark 1
*reversecontactnormals "test" 1 0
If indelems flag = 0 then the mark is empty as all elements in contactsurf are selected.
None.
