Creates a certain style of connector at locations specified by a list, with certain
rules and details, and realize the connectors using specified realization details.
*CE_ConnectorCreateByListAndRealizeWithDetails
entity_type list_id ce_style num_links link_entity_type link_mark_id solver_name
fe_type tolerance string_array number_of_strings
HyperMesh Tcl Modify Command
Creates a certain style of connector at locations specified by a list, with certain rules
- entity_type
- The entity type that specifies the location to create connectors. Valid values
are:
- Lines (for seam and area).
- Nodes (for spot, bolt, seam and area).
- list_id
- The ID of the list containing the entities. Valid values are 1 and 2.
- ce_style
- The style of connectors to create. Valid values are area, bolt, seam and spot.
- num_links
- The number of links to use.
- link_entity_type
- The type of entity to create links for. Valid values are comps and surfs.
- link_mark_id
- The ID of the mark containing the link entities. Valid values are 1 and 2.
- solver_name
- The target solver for realization.
- config
- The element type used for realization. Valid values are:
- 2 - plot
- 3 - weld
- 5 - rigid
- 21 - spring
- 55 - rigidlink
- 60 - bar2
- 61 - rod
- 70 - gap
- 104 - quads
- 1001 - custom
- fe_type
- The type ID for the current solver specified in the feconfig.cfg
file. Only used for custom config 1001.
- tolerance
- The maximum distance allowed between the connector and each of its links during
realization.
- string_array
- The ID of the string array that contains the additional input parameters. The string
array is created using the *createstringarray command. This should
always be set to 1.
- Valid creation parameters include:
- area_offset=<value>
- Offset area connectors created from node or line lists from the selected
location by this value. Default 0.0.
- area_width=<value>
- Width of area connectors created from node or line lists. Default 1.0.
- line_density=<value>
- The density for spot or seam connectors on lines. Default 0.0.
- line_offset=<value>
- Offset value from the ends of the line for spot or seam connectors on lines.
Default 0.0.
- line_offset_flag=<value>
- 0 - Do not offset connectors (default).
- 1 - Offset connectors.
- line_spacing=<value>
- The spacing for spot or seam connectors on lines. Default 1.0.
- link_elems_geom=<value>
- Specifies whether to connect elements (elems) or geometry (geom). Default
elems.
- link_rule=<value>
- The link rule. Valid values are now, at_fe_realize or none. Default none.
- relink_rule=<value>
- The relink rule. Valid values are id, name or none. Default none.
- seam_area_group=<value>
- Group flag for seam or area connector.
- 0 - No (default).
- 1 - Yes.
- tol=<value>
- Add entities as links only within this distance of the specified location.
Default 0.0.
- tol_flag=<value>
- 0 - Do not offset tol (default).
- 1 - Use tol.
Valid realization parameters include:
- ce_appliedmass=<value>
- The value of the applied mass. Default 0.0.
- ce_appliedmassdis=<value>
- The mass distribution type for apply mass:
- 0 - Apply to all nodes (default).
- 1 - Divide by nodes.
- 2 - Divide by area.
- 3 - Unit area.
- ce_areaconstantthickness=<value>
- The constant thickness when ce_areathicknesstype is 3.
Default 0.0.
- ce_areathicknesstype=<value>
- 0 - (T1+T2)/2 (default).
- 1 - Shell gap.
- 2 - Mid-thickness.
- 3 - Constant thickness.
- ce_areastacksize=<value>
- The density for area connectors. Default 0.
- ce_boltmaxdiameter=<value>
- The maximum diameter for a hole to be accepted as a bolt hole. Default
10.0.
- ce_boltmindiameter=<value>
- The minimum diameter for a hole to be accepted as a bolt hole. Default 0.0.
- ce_configfile=<value>
- The path and name of the FE configuration file. Default "".
- ce_connectivity=<value>
- 0 - Mesh independent (default)
- 1 - Mesh dependent + remesh
- 2 - Mesh dependent + ensure projection
- 3 - Mesh dependent + quad transition
- 4 - Mesh dependent + projection and find nodes
- 5 - Mesh dependent + find nearest nodes
- ce_diameter=<value>
- The diameter value for custom types (acm, cweld, mat100, and so on). Default
0.0.
- ce_dvstfile=<value>
- The path and name of the diameter versus thickness file. Default "".
- ce_fevectorreverse=<value>
- 0 - Do not reverse the direction for seam connectors (default).
- 1 - Reverse the direction for seam connectors.
- ce_forcecollinear=<value>
- 0 - Do not force collinear (default).
- 1 - Force collinear.
- ce_nonnormal=<value>
- 0 - Normal projection (default).
- 1 - Non-normal projection.
- ce_propertyid=<value>
- The ID of the property to assign. Default 0.
- ce_propertyscript=<value>
- The path and name of the property script file. Default "".
- ce_systems=<value>
- 0 - Do not build systems (default).
- 1 - Build systems.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using
*createstringarray.
Examples
To create a seam connector at the location of node list 66 55 65 to connect components 1
and 2 using a tolerance of 6.0 for
Nastran:
*createlist nodes 1 66 55 65
*createmark comps 2 1 2
*createstringarray 5 "link_elems_geom=elems" "link_rule=now" "relink_rule=none" "tol_flag=1" "tol=6.000000"
*CE_ConnectorCreateByListAndRealizeWithDetails nodes 1 seam 2 comps 2 Nastran 2 0 10.0 1 5
Incorrect usage results in a
Tcl error. To detect
errors, you can use the
catch
command:
# Handle error
