*voxel_lattice_hex_mesh_remove_constraints
Removes all planar constraints for the current voxel session.
HyperMesh Tcl Modify Command
This must be preceded by a call to *voxel_lattice_hex_mesh_add_constraints and must be followed by a call to *voxel_lattice_hex_mesh_create.
To create voxels of size 10 for include components 100-110 and exclude components 200-203, with a planar constraint at 500,0,0 along the positive x-direction, then remove the constraint and regenerate:
*voxel_lattice_hex_mesh_init 10
*voxel_lattice_hex_mesh_fill_voids 0
*createmark comps 1 100-110
*voxel_lattice_hex_mesh_add_entities comps 1 1
*createmark comps 2 200-203
*voxel_lattice_hex_mesh_remove_entities comps 2 1
*voxel_lattice_hex_mesh_add_constraints 500 0 0 501 0 0 1
*voxel_lattice_hex_mesh end
# Handle error
}Version History
2019.1
