*snap_nodes_to_original_geometry_location
Relocates moved nodes to their original locations on the surface.
*snap_nodes_to_original_geometry_location input_mark=<mark_id> input_type=<entity_type>
HyperMesh Tcl Modify Command
Relocates the selected nodes to their original location on the surface to which the nodes are associated. The input can be either a selection of nodes or elements.
- mark=<mark_id>
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- input_type=<entity_type>
- The type of input entity. Currently supported for elements and nodes.
*createmark nodes 1 234 235
*snap_nodes_to_original_geometry_location input_mark=1 input_type=nodesErrors
# Handle error
}Version History
2021.2
